12-09-2019
02:28 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-09-2019
02:28 PM
If your finish cut is really supposed to be at 7.249 then this probably isn't a programming issue. Your issue is at the machine. If this is only happening when you go to restart the tool, make sure you are starting all the way back at the toolchange or the M1 at the end of the previous op. My guess is you're starting further down the code and it's not picking up the tool and work offset.
If this is happening on every run, and not just when you go to restart a tool, then doublecheck your work and tool offsets.
