en respuesta a: kelbie.ockey
when i start to program i have the original setup that i leave alone and then i create setups after that as i need them, so say setup #2 has "Z" parallel to the pallet or floor. this is for a mazak vortex 5 axis mill. if i create my tool path in this orientation and then rotate the "Z" to say 90 deg the program will not work. i just tried this on a part and most of the tool path was correct but one tool, a drill which is using a pattern did not work and i had to reprogram the tool unless you know if a way to fix this i just reprogram the tool path.
