286 Vistas, 1 Respuesta
Syncronization as the first operation
I need to start the program with spindle synchronization on the Okuma Multus, after which the milling operation is on. When I first put the synchronization operation, the postprocessor displays the wrong code, I have to put a turning operation at the beginning, for example, the face, after it there is synchronization and then milling. The Face then has to be cut out of the code. How can I avoid this? Example and post attached
