287 Vistas, 1 Respuesta
Syncronization as the first operation
I need to start the program with spindle synchronization on the Okuma Multus, after which the milling operation is on. When I first put the synchronization operation, the postprocessor displays the wrong code, I have to put a turning operation at the beginning, for example, the face, after it there is synchronization and then milling. The Face then has to be cut out of the code. How can I avoid this? Example and post attached
en respuesta a: Anonymous
hi,
i think you have to modify your post,
the start program need to be reconfigured.
