783 Vistas, 9 Respuestas
FeatureCam 2019, adding tool list in NC code
I would like to have a tool list in the NC code. I have added the SetupInfoNCCode.bas Add-in and placed the (SETUP-INFO-MY-SETTINGS)<EOB> in the post I use. All it will do is print (SETUP-INFO-MY-SETTINGS) in the code. Not sure if I'm doing something wrong or if its not compatible with FC 2019. Any help would be appreciated. Thanks
en respuesta a: Anonymous
Hi
The addin does not work anymore
Use this, see screenshots.
If it helps you a Like and as a solution.
I wish you success
With best regards
Mathias Beyer
Hallo
Das Addin funktioniert nicht mehr
Verwende dieses, siehe Screenshots.
Wenn es dir hilft ein Like und als Lösung.
Viel Erfolg
Mit freundlichen Grüßen
Mathias Beyer
still no good. Loaded the streams.bas into the add-ins also. what am i missing here?
AJHanson
This is how i have my post set up
"program start"
%<EOB>
<PROG-NAME><EOB>
([uppercase(<FM-NAME>)])<EOB>
{N<SEQ>}(STOCK-DIMS)<EOB>
( PS95 TOOL-CRIB )<EOB>
{N<SEQ>}(TOOL-LIST)<EOB>
( <MCSID> - <REGION-DATE> - <TIME> )<EOB>
( FEATURECAM - MAKINO PS95 )<EOB>
( MACHINE TIME = <MACH-TIME> )<EOB>
( Stock On top Z=<STOCK-ZMAX> )<EOB>
<10>
{N<SEQ> }( <OP-PASS> <OP-TYPE> <SEGM-ID> )<EOB>
{N<SEQ> }<MOTION> <PLANE> <UNITS> G40 <F-UNITS><EOB>
{N<SEQ> }T<TOOL> M6 ( [uppercase(<TOOL-NAME>)] <TOOL-DIAM> DIA. )<EOB>
<INCLUDE:PlethoraOfPwords>
{N<SEQ> }G<FIXTURE> G90 X<X-COORD> Y<Y-COORD><EOB>
{N<SEQ> }S<SPEED> <SPINDLE><EOB>
{N<SEQ> }G43 H<OFFSET-NUM> Z<Z-COORD> <COOLANT>
<IF>[next_tool=true]<THEN>
<IFNOT><LAST-TOOL><THEN>
<BOL> T<NEXT-TL>
<ENDIF>
<ENDIF>
<EOB>
see it this helps
acad-caveman
Wait!
  Are you saying that in V2019 ( or above ) the setupinfo addin no longer works?
Does anyone have any information how and why did that break?
Seriously, for 90% of the parts we run here there is no setupsheet or traveler with an opsheet.
We just put the basic info - via the addins - into the header of the program
along with the tool list - also via an addin - and call it a day.
Please tell me that the "setup notes. bas" and the "add stock tool list and setup sheet.bas" still works!!!
Your formatting does not fit.
at & 1 the brackets () are not correct.
And in Featurecam the addin load.
Deine Formatierung passt nicht.
bei &1 sind die Klammern ( ) nicht richtig.
Und in Featurecam das Addin laden.
Mathias Beyer
acad-caveman
How do I get the correct brackets?
The two brackets are definitely too much.
see the screenshot.
good luck
It works! Had to start FeatureCam with Run as administrator (link below). Both examples above work as well as the SetupInfoNCCode.bas add-in. Thanks for your help.
https://knowledge.autodesk.com/support/featurecam-products/learn-explore/caas/sfdcarticles/sfdcartic...
