shawn.klug
388 Vistas, 1 Respuesta
undercuts on a lathe
I'm trying to turn a 1.5" hex shaft down to .5, using a left and a right hand 55deg tool. It starts ok, then starts rubbing/cutting on the back side of the tool, this tool should cut a 30 deg. cut no problem, then it starts hitting/cutting  on the backside of the insert before it gets to it finish diameter.
