Muppett1
en respuesta a: bhorstTGM48
Yes, this is still the only way to open 32 bit files in 2019 versions and later, and will also work in FCam 2018 as well.  The files can be opened as 32 bit, then saved in either 2017 or 2018 as 64 bit files.  Remember to make a copy of the file tho, just in case you need to open it in an earlier version as a 32 bit file.
