Craig-B
en respuesta a: julior873G4
@julior873G4,
You want to go to the following location (C:\Program Files\Delcam\FeatureCAM\Program) or (C:\Program Files\Autodesk\FeatureCAM 2017\Program) and run the Initdb.exe.  All depends if you're running FeatureCAM 2017 or an older version.  That will determine whether you go to the Autodesk folder or the Delcam folder inside of the Program Files folder.  Make sure FeatureCAM is closed when you run this executable, once you're finished you can re-open FeatureCAM and the (Basic) tools crib should be loaded as long as you selected to install the inch crib.
Craig Burney
Applications Engineer
