- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Charmilles 440sl
Can somebody that's ran a Charmilles Wire EDM help me get a working post processor made?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @smsunman805 ,
If you would like, find a post processor that is close in the library, create an Autodesk support case with any additional changes that are needed, and someone from the post team may be able to help you.
Will Watkins
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The post for the 440sl, doesnt include a number of missing elements, IE: Regimes (number of passes) S501-S504, Line for adding "tec" file, progressive offsets for number of regimes. Ill post a program that Esprit spits out. This is a program that Charmilles sent me for a test.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
this is an esprit post for a charmilles 440sl
O3750 (.3750 DOWEL HOLE)
G90
G20
G92 X0 Y0 I1. J0. H1.
G40 G50
(ROUGH PRIMARY CUT)
G11 (TEC,4PASS)
G10 P16 R0.
S501 H1.
M60
G41 D0 G01 X.187
G03 X-.1864 Y.01498 I-.187 J0
X.1846 Y-.02987 I.1864 J-.01498
M00
X.187 Y0 I-.1846 J.02987
M00
G40 G00 X.167 Y0
(SKIM PRIMARY CUT [ 1])
G10 P16 R0.
S502 H1.
G92 X.167 Y0 I1. J0. H1.
G42 D0 G01 X.187
G02 X-.187 I-.187 J0
X.187 I.187 J0
G40 G00 X.167 Y0
(SKIM PRIMARY CUT [ 2])
G10 P16 R0.
S503 H1.
G41 D0 G01 X.187
G03 X-.187 I-.187 J0
X.187 I.187 J0
G40 G00 X.167 Y0
(SKIM PRIMARY CUT [ 3])
G10 P16 R0.
S504 H1.
G42 D0 G01 X.187
X.187 I.187 J0
G40 G00 X.167 Y0
M50
M30
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @smsunman805 ,
If you would like help from the post processor team please follow instructions in my initial post.
Will Watkins
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
the post processors included are basically posts a tool path in an .iso format.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
attached is the post we have been using. This post will create the sub program then we have to create our command program manually with the , tech file, regimes, and part locations. In the Esprit post a command program is not required.
