en respuesta a: Anonymous
to do that you would need a radius end mill and have your curve below the tabs for the holes. As long as the shank of the end mill can clear the tabs and the diameter is small enough for your inside corners it should work. You will probably need to add plunge and retract points otherwise it will inevitably plunge into one of the tabs and cut it off.
