702 Vistas, 9 Respuestas
side feature will not finish the side wall
I’m trying to  a under I’ve tried z level and did not get the results I want. I started using side feature and it is roughing fine but only doing one pass on the bottom rather than several ones to finish the side from the top down. I have check the box that says finish wall. i have attached the file right now it is feature  side 42
