06-27-2019
01:33 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-27-2019
01:33 PM
Have created a new setup with 1st U.C.S central to pyramid, if you transform copy and rotate the facing feature in setup 2 then the preview looks ok but when you accept the facing operations are still in the same setup.
If you copy the feature into setup 2 & 3 then it will work.
When it comes to doing the hole on the side you cannot copy the feature into the other setups, but you can transform copy and rotate the hole to the other 2 components.
I think this will be limited to easier components and could end up getting complicated unless there is another way of transforming.
