- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Retrieving all my tools i.e Basic tools in Featurecam
It seems that all my tools in the tool library have disappeared .How do I recover/restore the tools in the tool library?? Mainly looking for the (Basic Tools).Thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @julior873G4,
When you say the Basic tools have disappeared, has anything been done recently to the PC to have possibly caused this? Have you updated to a new version of the software, something like that? Let me know when you have a second.
Craig Burney
Applications Engineer
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Are you attempting to recover custom tools you've created, or get back the Basic tool crib?
Craig Burney
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You want to go to the following location (C:\Program Files\Delcam\FeatureCAM\Program) or (C:\Program Files\Autodesk\FeatureCAM 2017\Program) and run the Initdb.exe. All depends if you're running FeatureCAM 2017 or an older version. That will determine whether you go to the Autodesk folder or the Delcam folder inside of the Program Files folder. Make sure FeatureCAM is closed when you run this executable, once you're finished you can re-open FeatureCAM and the (Basic) tools crib should be loaded as long as you selected to install the inch crib.
Craig Burney
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hopefully this worked for you and you're back up and running with the tool crib you were after.
Craig Burney
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @julior873G4
I am looking at the unresolved forum posts.
Has any of the replies helped you to solve the problem you were facing?
Do you need further help with this?
Can you please select the reply that solved your issue by clicking the "Accept Solution" button available under each reply?
Accepting a solution will mark your topic as solved, and highlight the reply in the topic so others having the same issue can more easily view the solution.
Kamalraj C V
Technical Support Specialist
