- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Partmaker 2020 could not create advanced surface machining at Win 10 Pro 64bit
Dear Partmaker team,
We have tested Partmaker 2020 on Win 10 Pro -64bit, but we found that could not create advanced surface machining. Finishing and Patern Finishing - NG.
Please see video for detail:
https://www.dropbox.com/s/mvwnxvwpa7fujyg/swiss%20milling.avi?dl=0
Then we tested Partmaker 2020 on Win 7 Pro -64bit, with same file, there is no issued (OK).
Please any advise??
Agus
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
***CORRECTION***
It actually looks like there may be some sort of conflict with PMK connecting to Exchange 2020. Disregard my comment about running 2020.
You want to run the 2018 COM register. This should correct the issue. Let me know if that works.
Kelbie Ockey
Sr. Implementation Consultant
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Kelbie,
Thanks for your advice. But still no improvement.
I try with 2 PC with same OS Win 10 Pro -64bit. The result was same. ASM only work for roughing toolpath.
Detail on video at attchment.
Agus
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hm interesting. Pinging @christian.poluch and @tatenda.mushonga. Do you guys have any ideas on what might be going on here?
Kelbie Ockey
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have the same problem but with Surface Projection tool paths.
I have tried the work arounds that used to work after ADEU 2019 caused the same problem with PMK2018.
It looks like an issue that the dev team need to look at fast!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Same issue, did this ever get a fix, haven't been able to do any finish surfacing?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Everything should now be fixed with installing v2021. With v2020 it depended on what version you were on and which version of Exchange was registered. Installing v2021 updates everything correctly.
Bill Cain
Sr. Technical Consultant
