731 Vistas, 5 Respuestas
Three 2016 FeatureCam Questions
I have three questions that may be an easy fix, but I am just to dumb to figure it out.
I have a Haas VF-4 with a 5th axis TR-160 table in it, and every time I create a part in 2016 FeatureCam it wants to say the table is an A & B axis table and not an A & C table. So when I load the NC Code into the machine it throws a code B drive disable because I do not have a B axis, only A & C. Is there a way to change this in FeatureCam without having to go into the NC Code tab and changing all the B's to C's by hand?
Next; when I run a machine simulation for a 5 axis part, FeatureCam always wants to tilt the A axis table at -90 degrees. So now when the part is being cut out I can not see what the cutter is doing in the machine. Is there a way to change this without having to go into the NC Code tab and changing all the -90's to 90's by hand?
Lastly; I have a riser block and a vise attached to the TR-160 table, is there a way to account for the offset in FeatureCam
as well.
Thank you for any help.
