05-06-2019
02:59 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-06-2019
02:59 AM
How can I make a trochoidal path for rouging that opened channel ? I've tried to make with curly corner but is not ok.
¡Resuelto! Ir a solución.
05-06-2019
03:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-06-2019
03:20 AM
Hi @grosucsm,
Thanks for posting on forum. Vortex for open pocket seems not possible.
To trochoidal mill an open pocket or side in FeatureCAM using the vortex strategy, do the following:
- Create a closed boundary. Where, the outside of the boundary is larger than the stock material. The boundary limits that are outside of the stock must be large enough to fit the complete diameter of the tool.
- Create a pocket or side from curve.
- Select the Stepover type option as Vortex.
- On the Pocket/Side properties tab, select Rough.
- Click on the Milling tab, and do the following:
- Select *Rough pass Z increment option, to change the Rough pass Z increment to the complete cutting length of the tool. This creates a toolpath with only one pass in the Z direction.
- Select *Vortex min radius option, to set the Vortex min radius to manually set the radius for the trochoidal movement. If values are left blank, then the system selects a default value.
Note: Changing the plunge point to a point outside of the stock boundary may be necessary if a ramping entry move is not desired.
Thank You.
Abhishek
05-06-2019
04:08 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-06-2019
04:08 AM
Thank you for your fast answer.. but when I am selecting Vortex strategy I can't select the Plunge point.
05-06-2019
04:12 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
