rwaldt
908 Vistas, 7 Respuestas
add tabs to the workpiece to hold while all other material is machined away?
HI,
Is there a function in featurecam 2019 like the Tabs function in fusion 360 "You can add tabs to the 2D Contour toolpath to hold the workpiece securely while all other material is machined away. Tabs are very useful when cutting thin plastic or wood material using 2D routers. "
en respuesta a: rwaldt
No I don't think so but it sure would be nice wouldn't it? those tabs really work great when you are using a vacuum table.
rwaldt
en respuesta a: Anonymous
ok, thanks
what is the best way to do this in featureCam?
francesco.caprini
Hi @rwaldt ,
I think you can use the clamp as a method.
See the below video.
Francesco C.
Application Engineer
rwaldt
en respuesta a: francesco.caprini
Thanks for the Help and the video.
francesco.caprini
Hi @rwaldt ,
thanks for your feedback.
If you have no other questions, I ask you to confirm what is proposed.
Thank you.
Francesco C.
It's still a lot easier in Fusion
JohnPorath
Hello, I just found this response but there isnt a video. Could you please send me a link to the video that was posted as this is an issue I'm having at the moment.
