hx
1026 Vistas, 10 Respuestas
Add example addins to the custom toolbar
At FeatureCAM 2016. exists the folder BulkEdit.In these folder exists lots of .wbm and .wbp files.
How can I add this add-in to my custom toolbar.
abhishek.juvekar
en respuesta a: hx
Hi @hx,
You can drag a button from View\toolbars\commands\macro to represent that button for bulkedit.wbp macro. Refer a video:
http://autode.sk/2idLXY0
If my post answers your question fully, please click on 'accept as solution' button or let me know if you have any additional questions.
Thank you.
Abhishek
hx
en respuesta a: abhishek.juvekar
Hi,juvekaa.
I drag a button from View\toolbars\commands\macro to represent that button for bulkedit.wbp macro.
But it alway throw an eeror:
(10013) Macro/module/project doese not exist. D:\Project Files\Delcam\FeatureCAM\Addins\BulkEdit\BulkEdit\BulkEditProject.wbp
Refer a video:
http://autode.sk/2iDtWjx
abhishek.juvekar
en respuesta a: hx
Hi @hx,
What is the version you are running with?
Thank you.
Abhishek
hx
Hi @abhishek.juvekar
My softwe version is FeatureCAM 2016, Version information show in the image.
Note: My computer system is Win10.
abhishek.juvekar
en respuesta a: hx
Hi @hx,
Thanks for providing the version details.
Can you open the bulkedit.wbp from View\Run Basic macro\ bulkedit?
If not, I am attaching a modified copy of the file "FCModule.wbm". Please replace your copy in Addins\BulkEdit with this one. I am attaching it with a text extension. Rename it to FCModule.wbm after downloaded and then replace. Now to run the addin:
1. close FeatureCAM if running
2. You may need to delete the INI file. This is to remove old references to the BulkEdit macro. The file is "EZFM_ui.INI" saved in C:\ProgramData\FeatureCAM
3. run FeatureCAM and from the addins dialog load addins\BulkdEdit\BulkEditProject.wbp
This should bring up the bulkedit menu with the button or from View\Run Basic macro\ bulkedit.
Hope this should solve the problem.
Thank you.
Abhishek
hx
HI @abhishek.juvekar
I replace the FCModule.wbm file and delete the EZFM_ui.INI.
But it still throw the error dialog.
abhishek.juvekar
en respuesta a: hx
Can I access your computer via team viewer? If yes, can you send me your email address?
Abhishek
hx
My email :hx@dekam.com.cn
hx
hi @abhishek.juvekar
At the VMware Workkstation.
I Create an new Windows 7 system and install the FeatureCAM 2016.
The the BulkEdit Main menu works right.
But the host system is Windows 10.
It still throw the error.
I don't known what is diferent beteen them.
hx
en respuesta a: hx
After a variety of modifications to the FCModule.wbm file.
I can not work around this problem after I re-install FeatureCAM 2016.
The problem is solved.
