- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @grosucsm,
Thanks for supplying the fm file.
In your fm file, you have created a pocket feature using Spiral with pre-drill operation. When multi-roughing with a pre-drilling operation selected, the second roughing operation or rest roughing operation uses the pre-drill location as its plunge point which is not sensible at all. This is why you are seeing those non-cutting moves from center.
This has been reported to the development team already and it is being considered for possible cause and solution.I have added this forum thread in the same.
As a work around, you can either change the strategy to Vortex but you will lose the ability to set pre-drill location.
Or you can create an independent drilling operation and uncheck pre-drilling from existing pocket feature. Then use the location of independent drilling operation as a plunge point.
Hope this helps. Let me know if you have any questions.
Thank You.
Abhishek
