bhorstTGM48
en respuesta a: jgulso
https://www.screencast.com/t/THvWPxkk0E52
This is the way the simulation looks on my screen from AJ's example of isoline. This appearance has nothing to do with the G code or the end result at the machine. If you look at the code from AJ's file it is mostly arc segments instead of all the little XYZ moves.
