368 Vistas, 3 Respuestas
surfacing radius on radial part
need a radius along/around radial part using z level surface mill finish. It seems to take a while, and alot of retractions. Is there a better way to accomplish this feature?
Please see .fm file Thanks!
rdbojan
en respuesta a: Anonymous
Hi @Anonymous,
You can try this one.
en respuesta a: rdbojan
@rdbojan,
I really like this, I have been trying to adjust parameters to get more of the full radius with no luck. Im thinking the logic behind this tool path is that it constricts within the curves. My idea is to offset the lowest curve inwards toward the pocket to get more depth, what do you say?
Tahnk you for your reply
rdbojan
Hi @Anonymous,
This is, maybe, closest to what you want.
I don't like movements in corners, maybe you can find it out.
