rfuentes
530 Vistas, 4 Respuestas
3D SPIRAL CHAMFER
Hello i am trying to 3d spiral this spiral but it is not working what is the best way to approach this?which surface mill option should i be using. program is for a 3  +2 vertical mill.
thank you.
bhorstTGM48
en respuesta a: rfuentes
I think this is what you need?
abhishek.juvekar
Hi @rfuentes,
Thanks for raising your query via Autodesk Forum.
I think Bill's toolpath answers your query. I have just modified it with leads Pocket center lead-in/out first. So it should plunge in the center, rather than plunging on the part.
leads_in_3d_chamfer.pngI have attached my part as well.
Thank You.
Abhishek
rfuentes
en respuesta a: bhorstTGM48
thank you yes this will work , i guess i was over thinking it.thank you!
rfuentes
en respuesta a: abhishek.juvekar
thank you
