jasonWXS2M
en respuesta a: Anonymous
Tracy,
   Are you wanting to export a tool holder profile from FeatureCAM? If so, I don't think that's what that dialog window is for. If you're trying to import a tool holder profile, to use for simulation for example, you have a few options. Several tool holder manufacturers, like Sandvik Coromant, provide 2D .DXF and 3D .STP models which can be loaded directly into the CAM software using the dialog in the picture in your original post. You could also create a .DXF file using measurements from your tool holder to define a curve that FeatureCAM can revolve around the Z-axis (a cross-section of half of the tool, essentially). Hope that makes sense.
Jason
