kotone.ojiri
626 Vistas, 2 Respuestas
[Do feed reduction for small moves] does not work when setting [TNR Comp]
The function of [Do feed reduction for small moves] does not work when setting [TNR Comp].
Please check the attached FM file.
<turn1>
 - Set [Do feed reduction for small moves]
 - Doesn't set [TNR Comp]
Feed rate value [1.0] which is set in [Do feed reduction for small moves] is output.
<turn2_tnr_comp>
 - Set [TNR Comp]
Feed rate value [1.0] doesn't be output
Do you know this is a bug or an intended move?
(FCAM-3733)
Kotone Ojiri
WWFO-CSO-Technical Consultant
Autodesk |
abhishek.juvekar
en respuesta a: kotone.ojiri
Hi @kotone.ojiri,
Thanks for posting on Forum.
When I was searching on track-record, I found an existing feature request to make it available with TNR. The feature request is Turn: Feed reduction for small moves does not work if nose-R is ON. It is requested to work even wh...
Hope this answers your question. If it does, please click accept as solution button. If it doesn't let me know.
Thank You.
Abhishek
kotone.ojiri
en respuesta a: abhishek.juvekar
Hi @abhishek.juvekar
Thank you for your response. It was very helpful!
Best regards,
Kotone Ojiri
Autodesk |
