454 Vistas, 2 Respuestas
The " end of line" snap does not work . cannot insert dimansions when 2D progr
The " end of line" SNAP" does not work
When programming 2D I cannot input  x and Z coordinates
it is just not there when I try to place dimensions in the x and z blocks
abhishek.juvekar
en respuesta a: Anonymous
Hi @Anonymous,
Welcome to Autodesk Community!
I tried to replicate the issue at my end but not successful. It is working fine. May be I am not able to understand the exact issue here. Make sure you have turned on Snap to end point in snap mode.
If this is not the solution, can you please elaborate the issue with the version of FeatureCAM you are running with?
Thank You.
Abhishek
Hi @Anonymous,
I can see that you liked my response. Does that mean your query has been answered correctly and resolved the problem successfully. If it is can you please click Accept Solution button , so that other users who has had a same problem, themselves can find this answer on internet.
If the answer doesn't solve your query, let me know with some additional information.
Thank You and have a great day!
Abhishek
