10-16-2018
08:59 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-16-2018
08:59 PM
Hi @Anonymous,
Welcome to Autodesk Forum.
Product help suggests related to Importing Autodesk Inventor files with FeatureCAM's natve import:
"You can import Autodesk inventor *.ipt files directly into FeatureCAM. Only the final 3D solid model is imported, 2D geometry, assemblies, and sketches are not imported. You can also import solids contained in Autodesk Inventor assembly files directly from *.iam files."
However, I had a try to import a simple DWG file form inventor that contains 2d geometry via Import using exchange and it works. So I believe import using exchange works. Can you please supply a file to investigate it in detail?
Thanks, Abhishek
Abhishek
