- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Importing a simple round design from inventor to featureCAM fails.
I just downloaded featureCAM and when I try to attempt to import a simple round .dwg part I get an unexpected error exchange failed. When i review the log I get, " To format:
sdxOptProcessWireframe:true
sdxOptSendParasolidAsParasolid:true
dtpOptTrimmedSurfaceImport:true
sdxOptExplodeSolids:true
sdxTolMaxFileComplexity:10000000
a2dOptExtrudedCurvesAsSurfaces:false
Exchange translation failed"
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Welcome to Autodesk Forum.
Product help suggests related to Importing Autodesk Inventor files with FeatureCAM's natve import:
"You can import Autodesk inventor *.ipt files directly into FeatureCAM. Only the final 3D solid model is imported, 2D geometry, assemblies, and sketches are not imported. You can also import solids contained in Autodesk Inventor assembly files directly from *.iam files."
However, I had a try to import a simple DWG file form inventor that contains 2d geometry via Import using exchange and it works. So I believe import using exchange works. Can you please supply a file to investigate it in detail?
Thanks, Abhishek
Abhishek
