- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Good afternoon FC Forum,
Im having another issue with the API. When I import a .cdb file from the API, for some reason FeatureCAM pulls the metric parameters, and displays/uses them as imperial parameters. This is not an issue when importing them manually from the Machining Configurations menu. See attached screenshots for reference. I pointed at a specific example where you can see that the metric data from the file is being used as imperial parameters.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Thanks for posting to the forum!
I have been able to replicate your issue and have reported it to development.
Behaviour seems to vary depending on the open document type. For example, try importing your configuration when a mm document is open, rather than an inch document. Does this change the result?
For your reference, the issue ID is FCAM-3655.
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
