325 Vistas, 1 Respuesta
FeatureCAM 2017/2018 Migration
Hi Technical Support team,
In Arthrex Inc., we’re migrating FatureCAM PartMaker 2017/2018 application Virtual Machine from current location to another, server name will be the same but the IP address will change.
What is the impact with the our users by making this change?
Can you please tell us your recommendations and send us documentation to be aware of all possible scenarios ?
Your support will be deeply appreciate it.
tatenda.mushonga
en respuesta a: Anonymous
Sorry for the late response. There shouldn't be any issue as long as you return the license first. You can do this by going to Help > About Autodesk PartMaker. Choose the "Manage License" button and you will see an option called "Return".  Once you've done that, you can activate the new install with the new IP address of the server. The PC/Virtual machine you are activating will need to be on the same domain as the license server. If you encounter any issues you can reach our licensing team.
