cfarber
439 Vistas, 5 Respuestas
Re: Feeds and speeds table (material)
I'm new to this and I don't know how to send a screen shot. But it's the 'Feeds/speeds And Cutting Data Tables' in Autodesk FeatureCam Premium 2019. I'm trying to create a new F/S table. First it says "to create a new F/S table click the 'new' button below. Then I name the material and fill out the feeds and speeds. there is no save option so I click on ok. The window disappears and the material is not saved. Thanks
anil_mistry
en respuesta a: cfarber
Hi @cfarber,
Since this is related to Autodesk FeatureCam Premium 2019 issue, I am going to move this thread to Autodesk FeatureCam Premium 2019 Forum board and someone from that team should be able to help you further.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
abhishek.juvekar
Hi @cfarber,
Thanks for posting on Autodesk Forum.
Did you try to open FeatureCAM as administrator? Right-click FeatureCAM icon and select Run as administrator. Let me know if it saves the material.
Thank You.
Abhishek
cfarber
en respuesta a: abhishek.juvekar
It asked if I will allow Autodesk to make changes to the hard drive on my computer when I do that.  What does it want to change?
abhishek.juvekar
Hi @cfarber,
It always asks when you try to open it as administrator. If you say Yes, it opens FeatureCAM, with admin rights to the folder where materials are getting saved which might have only user rights and that is why it is not allowing to save any new material. I hope it should solve your issue if you run it as administrator.
Thank You.
Abhishek
cfarber
No luck. I opened it as the administrator and it did the same thing. The window disappears after I click ok. The material name is still there when I open it back up but all the numbers are set back to 0 and it asks me to create a new material again. Thanks for your help though.
