en respuesta a: Anonymous
Hi @Anonymous,
You need to use a toolpath feature to get a lollipop to follow the curve, in the example I have created a lollipop in Radius 1.5mm then I have took your curve and copied that the radius of the tool down in Z so you are in the middel of the groove, You need also to offset the curve in XY so the lollipop only touch what you need on the part.
Hope that helps.
