en respuesta a: spencer.hardcastle
Ahhh yet another quirk withing the FC API! Your solution pointed me in the right direction. I assume your proposed solution was directed at milling setups, as I found that when creating a turning document, the Length, OD, and ID parameters need to be filled in for the stock curve to work. Thank you!
