12-14-2016
05:09 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-14-2016
05:09 AM
Thank you. That helps with one part of my two questions. The other questions
was why if after creating a second turn setup (using the opposite end of the
stock with Z pointing out from second end, ( 180 deg opposite from setup
one), when simulated, the tool does come in to the stock in the correct
direction towards the 2nd Z end but the tool has not turned around. It still
oriented the same as in setup1 (and of course crashes). Without using a
second tool, is any way to get the tool to orient correctly for setup 2
operations?
Charlie
operations?
Charlie
