spencer.hardcastle
en respuesta a: Anonymous
Hi @Anonymous
Thanks for posting!
You are correct. Using the method "SetDimensions" is the right way of setting a stock curve. There is a little quirk when setting a stock curve. This is that you need to set the width, length and thickness, even though they aren't used with a stock curve.
The code you can use to set a stock curve is as follows;
    Dim doc As FMDocument
    Set doc = Application.ActiveDocument
    Dim stock As FMStock
    Set stock = doc.Stock
    Dim curve As String
    stock.SetDimensions(,2000,2000,30,,,,,"curve2")
I hope this helps! If this answers your query, please accept this reply as a solution. If not, please reply to this post.
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
