540 Vistas, 2 Respuestas
API: Setting Stock From Curve
The FMStock member SetDimmensions() has an optional parameter of StockCurve with type string. My goal is obviously to generate the stock from an existing curve. If this member function is the correct way to go about the issue great, what is this parameter expecting? Ive tried passing it the name of the curve, and implicitly casting string to the Curve variable. If not what is the best way to do this?
Etiquetas (2)
