- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I attached a screenshot to show the a picture of what I need help with. I have to get a lollipop cutter and cut a undercut on this part. The undercut going around the part is a different heights. I do not know how to get Featurecam to do this. Can anyone help with this. This is being done on a three axis machine.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Can you share the part? go to File -> Share then tick what you need we know and attach the zippid folder.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have a curve to show where I need to cut. You will see a undercut that is flat. They are letting me use a lollipop cutter to cut the undercut. I just need to keep the land that is above the undercut. I can not figure out how to get a lollipop cutter to follow the form. Any help would be appreciated.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
You need to use a toolpath feature to get a lollipop to follow the curve, in the example I have created a lollipop in Radius 1.5mm then I have took your curve and copied that the radius of the tool down in Z so you are in the middel of the groove, You need also to offset the curve in XY so the lollipop only touch what you need on the part.
Hope that helps.
