kamalrajcv
en respuesta a: julior873G4
Hi @julior873G4
I am looking at the unresolved forum posts.
Has any of the replies helped you to solve the problem you were facing?
Do you need further help with this?
Can you please select the reply that solved your issue by clicking the "Accept Solution" button available under each reply?
Accepting a solution will mark your topic as solved, and highlight the reply in the topic so others having the same issue can more easily view the solution.
Kamalraj C V
Technical Support Specialist
