jasonWXS2M
321 Vistas, 1 Respuesta
PartMaker Links Feedrate
Does anyone know if it is possible to have PartMaker output a rapid feedrate for the Circular arc type of short link in an Advanced Contour Milling operation? I would like to avoid retracting the tool to the clearance plane in certain instances and instead prefer the positioning moves produced by the Circular arc short links, however, they seem to be executed at the cutting feedrate only. Is there a reserved word for the "rapid feed" specified in the Process Parameters dialog that I could use in the post processor?
Jason
billcainautodesk
en respuesta a: jasonWXS2M
Hello Jason,
I looked into this and I can see no safe way to do it. We don't know the rapid feed, we don't know it's a link. There is no logic I can come up with in the post to isolate the link move.
If you want I can look to see if I can make a better suggestion. Maybe a bit more explanation and/or a job file with what your looking to stay down with.
Bill Cain
Sr. Technical Consultant
