en respuesta a: Anonymous
A Variant type means it can be one thing or another (typically two choices, sometimes N!)
In this case, you can either pass the name of a curve, or the curve itself.  For instance, if you make a curve like:
Dim resultCurve As IFMCurve
Set resultCurve = curvePtList.AddCurveFromPtList(False)
' then you can pass the IFMCurve to the pocket
doc.Features.AddPocket(resultCurve, ...)
' or you can do as you do above, and pass the string name of the curve, as in,
doc.Features.AddPocket(resultCurve.Name, ...
