spencer.hardcastle
en respuesta a: Anonymous
Hi @Anonymous,
You are indeed correct by saying that you need to change the registry to alter which license you are using. There is actually a batch file that is distributed with the software that allows you do do this. However, this will probably work in exactly the same way that yours does.
The FeatureCAM development team are investigating a possible alternative, the suggestion is something simular to that of the other manufacturing products in our portfolio, such as PowerMILL or PowerShape.
Please refer to the following Autodesk Knoweldge Network (AKN) article for more infomation. Change Tier on Network Lisenses
Hope this helps,
Spencer
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
