brian_p1
651 Vistas, 3 Respuestas
5 axis roughing
Hi
Does anybody know of a way to get featurecam to rough levels using 5 axis to tilt the component away from the tool.
I have programmed it by making setups for each feature and rotating the y axis 15 degrees  to clear the tool holder but wanted to know if there is another way of doing this?
Have attached a file showing the setup for one feature using z level roughing to remove material.
en respuesta a: brian_p1
Hi @brian_p1,
You haven't 5 axis roughing strategies, so if you want this you need to play with the finish strategy and then use this as rough.
Sudhira
@brian_p1 wrote:
Hi
Hello @brian_p1 ,
Thanks for posting in Autodesk Community!!!
As i studied your issue and concluded that you want to avoid tool holder collision of component by tilting the tool axis. Here is the snapshot by which i have highlight the option. So please follow it. Also attached a revised toolpath FYR. If my post answers your query, please click on 'Accept as Solution' button.
Sudhira Dora
brian_p1
en respuesta a: Sudhira
Hi Sudhira,
If holder collision clipping is turned on then it only clips the toolpath to avoid a collision with material. It will not create a 5 axis toolpath to lean to component away from the tool. As J.D said this strategy is not available in FeatureCam for 5 axis roughing cycles
