en respuesta a: Anonymous
Hi @Anonymous
first things first:  for your previous question-> you can control the maximum ramp angle at the plunge tab.
The chamfer is not that hard to do but I noticed your second pocket finish operation is to deep, so you will destroy the chamfer. Roughing operation was okay ;-D
For the tool: Just do it like the 1/4" 90 degree tool :cara_sonriente_con_la_boca_abierta:
For the operation: Set the width and depth like you did and control the tool with "chamfer depth" in the milling tab. Maybe you have to create an offset curve (construct -> from curves -> offset) to prevent the tool colliding with the wall. I also noticed a 1/8" tool seems to be to big for the corners but maybe it´s okay for you. Please take a look at this.
Have fun :cara_sonriente_con_la_boca_abierta:
