en respuesta a: Anonymous
@Anonymouswrote:
Hi @Anonymous
I´ve took a look at your program. Looks not that bad if you ask me.
-I prefer deactivating "Bi-directional rough" in the strategy tab.
-For the pockets there are more then one way to remove the dead air cutting.
Example: 1. -> rough pass 2 -> like you did, will automatically not cut dead air.
                 2. -> the way you did in your edit
                 3. -> set the amount of the total stock for side operations -> milling tab
                 4. -> using an other stock modell like here: https://forums.autodesk.com/t5/featurecam-forum/different-stock-for-each-setup/td-p/7481845
If you need some more help please let me know :cara_sonriente_con_la_boca_abierta:
greetings from germany
Hello @Anonymous,
Thank you for your reply, your video examples on the STL files in use are exactly what I seen and followed. Very nice example.
I am going to post the most recent file I have, Im having troubles forcing a 60 degree x 1/8" chamfer mill feature to cut along a wall. If you can take a look and tell me what you think, thanks in advance.
Good morning from the US Hombre feliz
