en respuesta a:
05:38 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-22-2018
05:38 AM
Hi @Anonymous
I´ve took a look at your program. Looks not that bad if you ask me.
-I prefer deactivating "Bi-directional rough" in the strategy tab.
-For the pockets there are more then one way to remove the dead air cutting.
Example: 1. -> rough pass 2 -> like you did, will automatically not cut dead air.
2. -> the way you did in your edit
3. -> set the amount of the total stock for side operations -> milling tab
4. -> using an other stock modell like here: https://forums.autodesk.com/t5/featurecam-forum/different-stock-for-each-setup/td-p/7481845
If you need some more help please let me know ![]()
greetings from germany
