- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
When you update a solid model using an external CAD package, you can use the "Rerecognition Wizard" feature in FeatureCAM. This option is located in the "Construct..." menu, and will guide you through the process of re-creating, modifying or deleting the features in your document. First, import the new solid into the document, alongside the old solid model, and run the wizard. It will guide you through the selection of the old solid, the new solid and then follow the instructions provided to complete the wizard. Some feature might remain unchanged, some will require slight modification and some might require creating; all of which will depend on the scale of the changes that have been made to the original solid.
Hope this helps,
Spencer Hardcastle
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
