398 Vistas, 2 Respuestas
05-04-2018
12:53 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-04-2018
12:53 PM
I have a tube that has some windows cut out of the side of it.
When I create a toolpath for a feedmill to pocket out the window, there is a massive amount of wasted time, cutting air.
I have the stock defined as a tube...
¡Resuelto! Ir a solución.
05-06-2018
08:48 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-06-2018
08:48 PM
Hi @Anonymous,
Thanks for raising your query via Autodesk Forum.
Can you please verify the part or a solid stock a valid solid? You can verify that via Construct > Verify solid. Did you also try using stockmodel? If you can supply the part, I can take a look.
Thank You.
Abhishek
05-06-2018
10:16 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-06-2018
10:16 PM
This worked for the "side" feature toolpath, and kind-of worked for the "pocket feature".
Still working on an efficient toolpath for this... But thanks this did help
