268 Vistas, 2 Respuestas
Rough machining with Z level - problem.
Hello.
I have problem with rough machining. All tool paths are generated to max. height and whole cross-section. E.g. cone. Semi finished product and finish item is cone.  It makes tool paths as machining roller and machining air. What should I do to remove empty paths and fit rough paths to real shape? Thanks.
