en respuesta a:
04:41 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-23-2018
04:41 AM
I'm glad someone agrees with me. In fact here's a little trick I learned from an old timer many years ago when I was just a kid. You mention machining with a tap, well this guy did just that. He would cut worm gears using one. You run the tap at minimum RPM with your gear blank on a free turning shank bring it up to the tap and let it cut slow and easy as long as your diameter is right it will come out every time.
