463 Vistas, 2 Respuestas
Holder and Cutter library
I made a library for my tools and holders.  Where can I find the files so I can put these on another computer so that computer can see the library also.
abhishek.juvekar
en respuesta a: Anonymous
Hello @Anonymous,
Thanks for your contribution to Autodesk Forum.
If you have created tool cribs within tool manager in FeatureCAM, they are default saved at following location: C:\ProgramData\FeatureCAM\FeatureCAM 2018\DATABASEx64
This program data folder may be hidden. Make it visible.
However, there is an option 'Export' to export specific tool crib or tools, created by user in tool manager, to specific location on your computer.  Refer online help: http://help.autodesk.com/view/FCAM/2018/ENU/?guid=GUID-956EA6FE-2FE0-4976-BF30-22C6853E17BA
These cribs you can further copy on another computer and import them back in tool manager where you want to use.
Hope this helps.
Thank You.
Abhishek
en respuesta a: abhishek.juvekar
That worked for the tools I will test to make sure the holders came with it also.  Thank You
