abhishek.juvekar
en respuesta a: TomOliver
Hi Tom,
You can create your own custom templates, either by using the default templates as a starting point or making one from scratch. An option in the setup sheet dialog allows you to browse for your desired template. Refer  SetupSheetHelp.chm available at following location C:\Program Files\Autodesk\FeatureCAM 2018\addins\SetupSheet about more information about the tags currently available with html and excel template which are useful in creating a custom template. You can keep your custom template at the same location.
Hope this helps.
Thank You.
Abhishek
